Im am getting my RSTmodel ready for RSA.
But now applied loads are getting more difficult to distinguish as I assign more and more loads. See attachment.
They have the same color and I cant filter by loadcase (as far as I know). If I assign a load twice I couldnt even tell the difference! Am I missing something here?
How do you guys do it? Is there a possiblity to make the loads stack onto eachother as is done in other 2D calculationsoftware?
Alex
Solved by AlexDT. Go to Solution.
I've solved this... and I'm convinced that this is the proper way (correct if wrong). I define the weight of a material in the "thickness library". Then I assign self-weight to my model, I then only have to place the liveloads in my model.
When you are in the loads layout, you will see that there will be a loads windows with a list of the loads.
Otherwise you can rightclick select tables > loads.
Apologies but I'm a complete beginner with the software, and don't have the time to familiarise myself with the program unfortunately.
Where do I find these options exactly?
Many thanks for the help
Also: I've found the list of the load cases in the structural settings, but I'm specifically looking for the areas all these loads are working on or their total lmagnitudes, without having to find them individually in the viewport
@Anonymous wrote:
Is there also a way of seeing all the loads applied to your model? e.g. a list?
You can also create a Revit Schedule view which will list all of the load elements in the project.
You can use the filter tool to choose which loads are displayed in each view and how they are displayed.
I would set up a bunch of views and filters in my template to help with load visualization.
Joe
