Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Installed RISA link, now Revit won't launch
4 REPLIES 4
CraigGorsuch
1133 Views, 4 Replies
RISA link installer "RISAlink2011_900.exe"  (RISA 3D 8.1 and RISA Floor 4.1)
Revit Structural 2011, XP SP3,
I've deleted the UI dat file - Revit still doesn't launch
I repaired the installation - Revit still doesn't launch
I reinstalled (via Control Panel) - now AutoCAD Structural Detailing wouldn't start
Uninstalled and Reinstalled AutoCAD Structural Detailing
Uninstalled and Reinstalled Revit Structural - Revit still doesn't launch
Heard that a "solution" is to recreate the User Profile.  Hoping not to.
Anyone else ran into this?  What solution?
4 REPLIES 4
WinstonY
in reply to: CraigGorsuch
Hi Craig,
I was surfing forums and I found this post of yours. I believe we talked about this problem and you discovered that there was a problem with your Revit installation. I thought I'd share the link to where you obtained a remedy for this problem just in case anyone else encouters a situation similar to yours.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15145616&linkID=9243099&CMP=OTC-RSS...
Have a great day!
Winston Yaw
RISA Technologies
RevitGarage
in reply to: WinstonY
Craig, did you figure out what was causing this?  I'm tying to troubleshoot a computer right now and have tried all the usual fixes to get Revit up and running but still no luck.
CraigGorsuch
in reply to: RevitGarage
I found a solution…  I deleted WSCommCntrData.XML, and upon restarting Revit Structural 2011, the XML was recreated and the program launched fine.
Correlation is not causation, but perhaps the issues (corruption of the XML and the installation of RISA) just happened to coincide.
doug.mahoney
One of my people had Revit Structure 2011 crash on him, can't say for sure what he was doing at the time. Anyway, the program would no longer open. I installed, and even cleaned the registry prior to reinstalling, with no luck. I came upon this discussion while searching for a solution, problem solved. Thanks.
