The concept mass is an important part of Autodesk Revit, representing the architectural design styles toward freedom, abstract, distortion. It seems more suitable for dynamic wind loads. How to transform conceptual mass from design to the real construction with easy? That is to cast structures into a mass instance as a mould.
You can use the Structure Generator:
http://labs.autodesk.com/utilities/revit_structure_generator/?popupDownload=1
Hi, thank you for your attention. The Structural Generator is great, created by professors, but here I want to introduce an another way to transform, casting a structure into a mass as a mould. It is modeling with structural characters in one step, and models can be used directly by finite element analysis software without any preprocessing. No offence, just discussion. See the videos at youtube. "The power of Autodesk Revit" at: www.youtube.com/watch?v=xtvY_pP4NTU
and "The new feature of conceptual mass as a mould for casting structures in it" at: www.youtube.com/watch?v=D9pcLkLhfas
