Revit Structure
Member
Message 1 of 3 (211 Views)
How to make Autodesk Revit run more smoothly with 8-core?
211 Views, 2 Replies
11-06-2012 11:46 PM
My computer has 8 cores. When the Autodesk Revit is running,
the computer shows that only one of the eight coreis processing.
The other seven cores are not being used at that time.
How can I use the other seven cores together to make the Autodesk Revit run more smoothly
and quickly?
My processor model number is Intel(R) Core(TM)i7 CPU  950 @  3.07GHz   3.07GHz
Looking forward to your soonest reply.
Best regards & Thanks,
Kevin
Message 2 of 3 (209 Views)
Re: How to make Autodesk Revit run more smoothly with 8-core?
11-07-2012 02:30 AM in reply to: 732861
Which version are you running?
Then look at tht post http://revitit.com/blog/?p=443
Valued Contributor
Message 3 of 3 (160 Views)
11-19-2012 12:23 PM in reply to: dhurtubise
Thanks for this link. I set all my cores to 100% and it made a significant improvement working with large models.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
