Extract from Autodesk help below:
- To access Help offline or stored in another location
Do the following
- Set UseHelpServer=0.
- If you want to use the local copy of Help, save changes to Revit.ini, and restart Revit.
- If you want to use a copy of Help stored in another location, add the setting HelpFileLocation, and specify the path or URL to the help system.
[Documentation]
UseHelpServer=0
HelpFileLocation="M:\RevitResources\Help\en-US\WBH"
HelpBrowser=0
- Save changes to Revit.ini, and restart Revit.
To access local Help
From the software, press F1 to access context-sensitive help. When the software detects that you are working offline, it automatically accesses the locally stored help files and displays the appropriate help topic.
To open the Help system for browsing, do the following:
- Navigate to the software installation folder: %ProgramFiles%\Autodesk\<product name and release>
- From that location, navigate to the following folder: Help\en-US\WBH (or your language-specific equivalent).
- In the WBH directory, double-click index.htm to open the landing page for the Help.
