Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
How-to cut steel beam ends
2 REPLIES 2
2383 Views, 2 Replies
I have sloped steel w-beams connecting over HSS sq. columns - the colums and wall they are in are not perpindicular to the beams. (The intersect at an angle)
I have two questions. 1. What's the best way to cut the beam ends so that the cut end is parallel to column face and wall, and...2. how do I cut beam end face so that it is plumb cut to col. face and not perp. to beam slope?
2 REPLIES 2
VWD-MLM
Hi Shawn,
Try using Refernce lines to Trim the Ends of the Beams at the Columns Lines and tails.
Mike
Michael L. Maloney
Virtual World Designs
VDC & BIM Model Design, Clash & Coordination
mike@VirtualWorldDesigns.com
BDSU 2015, 2016
Charlotte, NC ; Fort Mill, SC
in reply to: VWD-MLM
Thank you... but I think i need a bit of schooling on how to create and use reference planes and lines.
SG
