Revit Structure
Member
fbratton
Message 1 of 2 (302 Views)
Accepted Solution
How to Update Rebar in a Revit 2011 Model from ISM Repository
302 Views, 1 Replies
05-03-2012 09:24 AM
I used a Revit 2011 model to create an ISM repository, which I subsequently used to create a RAM Concept model for slab design.  After designing the slab in Concept, I was able to update the repository with the rebar information, with all of the rebar showing up as a property called "Rebars" in the "Properties" table for the slab.  I can also view all of the rebar in 3D in the ISM viewer.  However, when I try to update the Revit model from the repository, the the new slab does not have a property called "Rebars" when viewed in the Structural Synchronizer, and no rebar is created in the Revit model.
Is it possible to update a Revit model with rebar from an ISM repository?  If so, how?  Any direction would be much appreciated
Product Support
Chris.Aquino
Message 2 of 2 (286 Views)
Re: How to Update Rebar in a Revit 2011 Model from ISM Repository
05-08-2012 09:11 AM in reply to: fbratton
As the code which handles the updating is written by a 3rd party, I would check with the creators of the ISM Plugin.
Chris Aquino
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
The Revit Clinic
@Revitclinic
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
