Dear all
I want hidden rebar for slab in structural plan
In rebar slab I draw as method tool AREA and PATH
please see picture
THANKS ALL
There are many things that could be causing this.
First, make sure that the view is a hidden line view.
Then, select the Area/Path Reinforcement boundary, and in the property palette, Press the "View visibility States" "Edit" button.
For any views that you do not want the rebar visible through the host, uncheck the box next to the view name in the “View Unobscured” column.
Joe
OK Thanks you
But I think it not ans for my question
please see picture
thanks you
Thanks you
So, Do you drawing detailing in revit structure?
If you do work it in revit structure, Can you guide me ?
thanks
are you able to test Revit Meridian beta version?
Regards
Ewa Jachym
