Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Hidden lines on footings and pedestals
2 REPLIES 2
mdaskilewicz
616 Views, 2 Replies
I have a phenomenon where when I added a pedestal (concrete column) to the bottom of my steel column and moved the footing down to the bottom of the pedestal, the footing, which showed in hidden lines because it was beneath the floor slab, is now shown in solid lines--even though it is still below the floor slab. The pedestal is also showing up solid line instead of hidden.
Changing the Detail Level or Graphics Style doesn't help.
Any ideas as to how to get them back to hidden lines?
Mark in Philly
2 REPLIES 2
The footing probably now falls between the "Bottom of the Primary Range" and the "view depth".
Any objects in this range are rendered in the "Beyond" linestyle.
To change this:
Select the view, and go to its properties dialog.
In the "Extents" section of the properties dialog, push the "Edit" button next to "View Range".
Set the "Bottom" value (of the Primary range) to be the same as the "View Range".
Joe
mdaskilewicz
in reply to: mdaskilewicz
Thanks. That did it.
I always get frustrated trying to adjust the View Range. It never seems to behave the way I expect it to.
Mark
Rail Community
