Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Hanger columns
3 REPLIES 3
kevms
918 Views, 3 Replies
Hanger columns
Hello All
I have two high beams and and I need to put in two hanging columns. Can anyone tell me how to do that
Thanks in advance
Kevin
Kevin
Using Revit Structure 2012, 2013, 2014
I think I am getting the hang of this revit stuff
3 REPLIES 3
Chris.Aquino
in reply to: kevms
I would place your columns from the level above (the top of the column), then use the Top and Base Offsets to control the top and bottom of the columns.
I would appreciate it if you would let me know if this answers your question. If it does not, please reply with more information about what you are trying to do so that I can provide a better answer.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
kevms
in reply to: Chris.Aquino
I already figured it out a few days ago, instead of having the column based on height, I changed to depth and then added a base offset to where I need it to go.
Kevin
Kevin
Chris.Aquino
in reply to: kevms
Thank you for let me (and the rest of the community) what fixed the issue.
Chris Aquino
@Aquinotecture
