Revit actually uses 3 place decimals for HSS-Round Hollow Structural
Sections; example: HSS16X.500. In this they are closer to the AISC standard
designation, but not quite. Notice the capital "X" they chose while AISC
chose lowercase "x" as you noted.
The way Revit makes these members, it pulls data from a text file,
\Revit\Imperial Library\Structural\Framing\Steel\HSS-Hollow Structural
Section.txt, or
\Revit\Imperial Library\Structural\Framing\Steel\HSS-Round Structural
Tubing.txt,
which can be easily edited to produce correct nomenclature (I have done this
and it works). There is a separate text file for each of the shape families,
as well as another set of text files for columns which have different
parameters than framing members. The rub is that all said text files would
be overridden when the next release gets installed so you would need to
re-name families and text files to preserve your editing.
How very arrogant of Autodesk to reject industry standard nomenclature in
the first place!
I've heard that the decimals for the square/rectangular HSS's have been
corrected to fractions in the latest release, but haven't seen it yet. We
can only hope that they corrected the "X"s as well. This is an easy fix that
Autodesk should rightly do, we shouldn't have to.
wrote in message news:5819909@discussion.autodesk.com...
I have noticed Revit uses decimals is the thickness is square and rect.
HSS's. However it uses fractions for the diameter in HSS pipes. In our
office we call out square and rect. HSS thicknesses with fractions, which is
the standard in AISC, example HSS4x4x1/4. We also call out pipe sections
per AISC using decimals to the third place ex. HSS4.500x.237 I assume Revit
did it this way because of the transferring of files with the analytical
software. i was just wondering if other structural firms were sending out
drawings in Revit using it's HSS designation or are you changing the tags to
read per AISC. If you are changing the designations than how? And does it
cause any problems with the transferring of information between the
analytical programs.
