Revit Structure
Valued Mentor
AJA14
Message 11 of 12 (127 Views)
Re: Graphics problem in Linked Reinforcement model in Revit
02-12-2013 04:45 AM in reply to: RNDPIS
Hi. I received your files and checked them. You are right. What seems to be happening is the following:
1- In each separate file you are changing the visibility settings of the rebars to be unobscured and solid.
2- When you linked file B in file A the rebars lose this setting. I actually binded the link, went into group editing mode, and then checked the settings. The two checkboxes were cleared.
It seems that this is an error that autodesk needs to to take a look at unless we both are missing something. I will try to find a workaround while keeping the file linked. Otherwise, your best option would be either to bind, or create as a group and load, or use phases instead.
Regards.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Message 12 of 12 (117 Views)
02-12-2013 11:16 AM in reply to: AJA14
I have taken a look at the files and AJA14's comments, and have found that this was recently submitted to our development team by another user. I have added this thread to that report. At this time the development team has not identified a time frame on when we can expect to see this addressed. Unfortunately I do not have a better workaround other than binding the link or maybe Copy/Monitoring the floor and adding reinforcement native to the host file. I am sorry for the trouble that this causes to your workflow, and hope that we see something implemented soon.
Katie Langan
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
