Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Exporting to Navisworks
2 REPLIES 2
Barryfisher
287 Views, 2 Replies
Guys
I'm very new to Revit and wish to export a model into Navisworks.
Any suggestions would be very helpful.
I've used Navis with 3d+ but not Revit...
Cheers
2 REPLIES 2
KSI_Thor
in reply to: Barryfisher
Go to your 3-D view in Revit and export as a DWG file. You can open that file in Navisworks.
Hi
If you have Navisworks JS installed on your computer re-install it and select modify then you can select the Revit Structure 2008 plugin.
This will add the Naviswork Export to the tools menu under external Tools.
Ive had a few problems with this with regard to scale and origin (unless you have set up shared coordinates) so exporting as a drawing maybe better.
Hope this helps
