Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Exported hatches are called FP_* in AutoCAD
3 REPLIES 3
rrijswijk
2184 Views, 3 Replies
I created some Custom Fill Patterns by importing the different pat files into Revit. Works great. At the export pattern mapping I use a similar PAT file to generate a good DWG file. However, for some reason the hatches in AutoCAD are called FP_* (asterisk is a number starting with 1). I checked the AutoCAD options, and the path to the pattern files is correct. How can I generate a DWG with the correct hatch names (instead of FP_1)...
3 REPLIES 3
rrijswijk
in reply to: rrijswijk
I had a Revit project that works fine. By using Transfer Project Standards (DWG Export settings) I was able to transfer the right export settings. Now, the correct names are shown in AutoCAD as Hatch patterns.
Unfortunately, I do not know what went wrong still.
===Edit===
Further researched it. The fill pattern that I exported now, was a simple Revit one. Not a real CUSTOM pattern. So, Revit translates the pat-file to possible Revit fill patterns. If that not succeeds, it will use the custom pattern setting. However, that is not working properly
Joe.Charpentier
Thanks for providing an update.  I'm sure your post will help someone in the future!
joe
rrijswijk
in reply to: Joe.Charpentier
It took me a long time, to find out how this works
When will this be fixed?
Gr. Renzo
Rail Community
