When I use revit extensions civil structures - Roads and terrain I get the following error:
Extension encoutered a problem.
The error occured on: AREX
- Create method exception.
Assembly name: DBridgeRoad: Object reference not set to an instance of an object.; StackTrace: at REX.Bridges.Common. ...
How do I solve this problem?
Hello Maarten
did you ever get a reply to your query, we're running the bridge extension here too and getting the same or a very similar error?
Regards
Neil
Hi Maarten
thanks for the reply, looks like this will take a while to fix??
I have solved my problem!!!! Aparently the problem was the size of the file, because My project was 14 Km long, so I limited the proyect only to the bridge zone and I was able to make the export process
