Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Error message while using Extensions Revit 2013
5 REPLIES 5
MaartenBroersen
813 Views, 5 Replies
When I use revit extensions civil structures - Roads and terrain I get the following error:
Extension encoutered a problem.
The error occured on: AREX
 - Create method exception.
Assembly name: DBridgeRoad: Object reference not set to an instance of an object.; StackTrace:    at REX.Bridges.Common. ...
How do I solve this problem?
5 REPLIES 5
Sterneo
in reply to: MaartenBroersen
Hello Maarten
did you ever get a reply to your query, we're running the bridge extension here too and getting the same or a very similar error?
Regards
Neil
MaartenBroersen
in reply to: Sterneo
Hello Neil, No. Unfortunately I have no response received. Therefore, I have the error sent to Autodesk in end December, but still waiting for reply. Regards, Maarten
Sterneo
Hi Maarten
thanks for the reply, looks like this will take a while to fix??
cgonzal
Hello, I am having the same problem with the Civil Structures extension for Revit 2016.
cgonzal
I have solved my problem!!!! Aparently the problem was the size of the file, because My project was 14 Km long, so I limited the proyect only to the bridge zone and I was able to make the export process
