Revit Structure
New Member
wooster22
Message 1 of 3 (612 Views)
Elements won't print
612 Views, 2 Replies
11-09-2012 05:35 AM
I'm using Revit 2013 structure, and when I go to print my plans, some of the slab edges and roof trusses won't print.  They don't show up in the print preview either.  I tried printing to PDF instead of the printer and had the same problem.  If it were all of the edges or trusses I'd think it was a visibility setting, but it will print the edges in part of my building, but not other parts.  I'm running on Windows 7, 64 bit.  Any ideas?
Distinguished Contributor
lzaras1
Message 2 of 3 (605 Views)
Re: Elements won't print
11-09-2012 07:44 AM in reply to: wooster22
I had a similar issue with foundations, though they ~did~ show in the print preview.
I contacted Autodesk about my issue and they said they didn't have a fix for it, yet.
The workaround for us was to plot using RASTER processing instead of Vector.
Give RASTER processing a try and if that doesn't work, maybe others will have other suggestions.
Leanne Zaras, CDT, LEED AP
AutoCAD 2010 Certified Professional
Revit Architecture 2012 Certified Professional
New Member
wooster22
Message 3 of 3 (600 Views)
11-09-2012 09:53 AM in reply to: lzaras1
I tried Raster vs. Vector printing, and that didn't work.  However, what we did find was that if I changed my foundation plan to Wireframe, all of my slab edges will print.  Unfortunately that doesn't work for the roof framing plan.  To get the roof framing to print, I set the visual style to Hidden Line and turned off my roof.  Even having the roof set to 100% transparency didn't work.  It's a somewhat random solution, but I can print.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
