I have problem with link CAD in revit, every time i update the link CAD in plan view.
My structural object in revit can not be shown properly, because of updated Link CAD layer.
Did revit has draw order (Bring to front or send to back) like autoCAD did??
Ben
Solved by hyppoh. Go to Solution.
Hi Ben
The answer to your question is no, i've spent some time trying to resolve the same issue and after posing a similar question on this forum and speaking to our reseller support team i still haven't resolved it. One thing you can try is change the link to half tone as that sometimes helps a little. This i agree is quite annoying..
Good Luck
Cheers Barry
Have you tried changing the properties from "foreground" to "background" when selecting the CAD file in the view?
Good idea, but it still can't.
I rather to use hidden than wireframe in visual style to bringt element to front.
If i see Tutorial in subscription, i saw that is possible to get arrange tool : bring to front / send to back.
How can i get that tool , by RMC cad layer?
What works for me is not usign the draw order, but rather to make the CAD link transparent. Here is the process I used.
Right click on CAD link in your plan > override graphics in view > element > check on the Transparent box > then ok
See if it works for you.
I've tried doing this but got the exact same results. Is it something to do with making the CAD link halftone?
Select your CAD link. And in the properites dialogue box you can change the DRAW LAYER to background.
it is called underlay in visibility view under revit link once you select it the revit link go beyond your plan
@gopal567.live hello, omg, after 4 years +++ you answered his question? thanks
Hi Ben,
I know this is a super old post, and you've probably found your answer by now. It might be useful to someone though.
There is a draw order button (i'm on revit 2016) - if you select your link (you need to do it as a whole, cannot separate the layers if the CAD is still linked, only if you attach it I believe). Select the CAD, and from the "modify" tab click on "bring to front" or "send to back". There's a drop down menu (send backward or bring forward) See print screen 1, below. However, you might need the "draw layer" from the properties, which has a "foreground" or "background" option (second print screen below. I hope this helps.
This link was really helpful to me to switch the order of two stacked views. It can be two or multiple floor plans, switching two perspective 3D views, etc.
This works well.
visibility graphics/ revit links / select a link and check underlay.
Hi All,
I know this is an old post but I was looking for a solution myself and came up with; if you have some CAD links in your model a cheat may be to change the vertical elevation of the links. Traditionally you will only be using CAD links as underlays on plan views. So why not arrange them with a vertical elevation (where possible) in the draw order you want? So everything at elevation of zero for background info and then elevation of 1m above for the stuff you want over it. Then keep working your way up. Obviously if you are using 3D items then this will impact elevation of any lines you pick. You control the elevation via the "base offset" in the properties box for the linked cad.
Make sure your CAD drawing is flattened (flatten command). This may be what caused it to previously work but not after an update. When you link the CAD (without the current view only checked) the CAD entities come in at their own height so a line above the Revit object will cover it.
