So, new to Revit and this is doing my nut!
I have two vertical members at a distance apart. I then add a horizontal member at the base of these vertical members and everytime the end points of the horizontal member snap back a distance from the vertical end points.
Is there a setting or way to stop this happening?
Ta
If I am understanding your question, I believe you are referring to the beam cutbacks (visual representation of a gap between adjoining members). In the Manage tab, under Structural Settings, there is a tab called "Symbolic Representation Settings." There are some variables you can adjust for member cutbacks. You could set beam cutbacks to 0". If you adjust this setting, your model should update accordingly, so you won't have to go back and adjust your already modeled members. Hope this helps.
