Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Default Notch settings
3 REPLIES 3
alb01
3017 Views, 3 Replies
Does anyone know how to change the default notch setting from 20mm to 10mm. I am sure there is a simple way to do it, but cant seem to find it.
3 REPLIES 3
Orsolya.Balazs
in reply to: alb01
Dear Andy,
If I understand the situation correctly you would like to know how to change the default cope setting. It seems the deafult setting is hardcoded in revit, so you may need to modify posterior the value for cope.
I have created a short movie about how you can change it: http://screencast.com/t/ZbYvIdYsjY
You need to apply first the cope command on the appropriate elements (in my sample between beams) and then, only after this step, the parameter "Coping distance" will appear under the beam' instance properties. Here you can then modify the cope's distance value.
Hope this helps.
Kind regards,
Orsolya Balazs
Orsolya Balazs
Product Support Analyst - AEC
Autodesk, Inc.
alb01
in reply to: Orsolya.Balazs
Thanks Orsolya,
but it looks as this solution would need to be applied to each beam after being inserted. I want to set the coping/notching distance to say 10mm so that whenever i apply a notch the 10mm is the default distance. currently, after opening revit and starting a new project, the notch distance defaults to 20mm. Please see http://screencast.com/t/KE2IQYEs2C
Dead link. eadff
Muthomi Munyua
