Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
DBlink not functioning
1 REPLY 1
kishore152
337 Views, 1 Reply
hi all,
I could not export the revit data using DB link as nothing is getting highlighted to click on next.
Is there anything extra that I need to install apart from MS Access or should I follow a specific procedure before I go to addins.
Please suggest.
Please find the attached screenshot for the problem I encountered.
1 REPLY 1
Make sure that MS Access and Revit are both 64 bit version. If MS Office is 32bit version  and Revit is 64 they will not see each other. I believe that DB link doesn't support 32bit MS Access.
You can try to look at these two old links:
http://www.revitforum.org/architecture-general-rev​it-questions/1384-db-link-3.html#post40942
http://www.revitforum.org/architecture-general-rev​it-questions/1384-db-link.html#post13639
..Vg
