Revit Structure
Valued Contributor
Message 1 of 3 (163 Views)
Copy Monitor is puzzling
163 Views, 2 Replies
11-02-2012 12:10 AM
for the first time I am working with a client who is producing an architectural Revit model. I am trying to use the cross linking method of collaboration. I copy-monitor the walls and two strange things occur. One is the location line set  by the architect as face of finish reverets to center of wall when I copy it. Is this usual? The last setting for location lines before I copy is face of finish in my file. Second, some of my wall intersections would not cleanup. I figured out that I had to reset (wall) profile to get them to clean up. I checked the architects drawing and he didn't alter any of his walls with profile linework. He did use attach to roof in some instances. Is this usual behavior for Revit using copy monitor?.
Distinguished Contributor
Message 2 of 3 (157 Views)
Re: Copy Monitor is puzzling
11-02-2012 06:00 AM in reply to: ArthurMacLeod5818
for the reasons you mentioned (Copy/Monitor on walls has worked that way for as long as C/M has been around) we do not use C/M on walls.
The only thing we use C/M for is Grids (if we didn't create them) and Levels.  If we (Structural) create the grids, then the Architect C/M's ours after our DD package is submitted.
Leanne Zaras, CDT, LEED AP
AutoCAD 2010 Certified Professional
Revit Architecture 2012 Certified Professional
Valued Mentor
AJA14
Message 3 of 3 (139 Views)
11-04-2012 10:07 PM in reply to: lzaras1
The workaround suggested by Autodesk for the time being is this:
Don't duplicate the walls using C/M feature. Instead, manually draw the structural wall and then use Align to the Location Line of the linked .rvt wall. Once done, you can “Monitor” only feature. By doing so, Revit will remember the offset distance between the center lines of manually drawn walls and the linked wall. it is a pain to have to do it on each pair of walls.
To read more please go to:
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User%27s_Guide/2214-Collabor2214/2357-Multi-D...
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
