Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Coping Settings
3 REPLIES 3
aslusarenko
1329 Views, 3 Replies
Coping Settings
Is there any place where I can set up Settings for Coping in Revit Structure?
3 REPLIES 3
What kind of Settings would you like to set?
Joe
aslusarenko
in reply to: aslusarenko
I want to set up how the coping is done. The set back distance, how it looks, etc. I just have not found anywhere in the program that I can manipulate the set up of how coping is done. Do you have any suggestions?
The set back distance is an instance parameter of the coped member.
That is the only setting there is. It's fairly limited, really only allowing the user to make a "nicer picture" where neccesary, rather than a full steel detail.
Joe
