Revit Structure
Active Contributor
Message 1 of 3 (2,176 Views)
Convert ACIS to Polymesh objects
2176 Views, 2 Replies
10-03-2012 10:21 AM
Importing autocad piping into project and recieve the following error : 'ACIS objects could not be imported, use qutocad to convert to polymesh objects'   any help would be appreciated !
Product Support
Message 2 of 3 (2,162 Views)
Re: Convert ACIS to Polymesh objects
10-05-2012 04:32 PM in reply to: kentanner1346
If you are using an AutoCAD MEP DWG file, have you tried going through the steps in the following blog posting:
Importing 3D geometry from AutoCAD MEP into Revit MEP
http://revitclinic.typepad.com/my_weblog/2011/04/importing-3d-geometry-from-autocad-mep-into-revit-m...
I also found the following help topic with information on the type of ACIS objects that Revit supports for import:
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0061-Start_a_61/0066-Using_In66/007...
Lance Coffey
Active Contributor
Message 3 of 3 (2,130 Views)
10-15-2012 05:30 AM in reply to: Lance.Coffey
Files where exported into dwg format from CATIA. Don't and can't find alot out about this application, however found if I would explode and purge the files I could then turn them into blocks... worked fine for what i needed.. recorded a little macro and 57 files in about 2hrs...
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
