is there any way in using load combinations in this tool?
I seem only to be able to apply loads but not use them to create combinations.
Is this just a reminder that the tool maybe should eventually work in a project environment where combinations can be created in the Structural Settings? In the Conceptual Mass Family Editor I can't setup loads/load combinations to use them with this module.
Thanks for any help,
Klaus
...Also, i can't change the material definition in the "Geometry"-Dialogue. When I change it to something other than the predefined it always switches back to the predefined value as soon as I deselect the surface and select it again. Doesn't let me choose a dedicated material either. Bug in front or inside Computer?
Cheers,
Klaus
