Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Column to beam connection problem
1 REPLY 1
t.donov94
486 Views, 1 Reply
I want to ask is anyone else getting a message
"Column geometry is incorrect"
It comes when I try to make a connection between a beam and a columns (steel S275). The column and the beam are also the same size.
If this is from any help I am using revit 2014, with extention on a mac with parallels running windows 8.1.
Tsvetan
1 REPLY 1
t.donov94
in reply to: t.donov94
I also want to add that when I play with some of the setting the message changes to beam geometry is incorrect.
