Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Beam tag??
7 REPLIES 7
Message 1 of 8
goodjp
1490 Views, 7 Replies
Beam tag??
I need help. I am trying to create a beam tag that has " & L" after the beam size. Any help would be much appreciated. I was trying to create a custom parameter but I am not sure if I am missing something or that it can not be done. I am thinking more of that I am missing something
7 REPLIES 7
Message 2 of 8
AJA14
in reply to: goodjp
Hi. This should be fairly easy. When you create the label go to the edit label dialog and add the prefixes and suffixes you need which may be simple text or may be other parameters.
Regards.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Message 3 of 8
huyxp
in reply to: AJA14
how to create tag Beam have number increment, example: B11,B12,B13( at B11 , 1 first is number storey 1; 1 second is Beam 1)
please help me
Message 4 of 8
huyxp
in reply to: huyxp
Dear all
How to create a tag Beam have number increment.
example: at storey 1: B11,B12,B13...
                at storey 2: B21, B22,B23 ..
                at storey 3: B31, B32,B33,...
Bij ( i is name of number storey and j is order number of beam)
please help me
Message 5 of 8
AJA14
in reply to: huyxp
Well, supposing you are not going to create any shared parameters you could do the following.
1- Edit family for tag
2- First Label = type mark, Prefix = B
3- Second Label = Mark
4- Save as new tag and load.
5- For each floor create a new type for the beam, Say B400x500-1
6- In type properties, input 1
7- In instance properties, input 1, 2, 3, ...
8- In second floor create new type, Say B400x500-2
9- Repeat Process
Ali Al-Hammoud
Message 6 of 8
huyxp
in reply to: AJA14
thanks pro very much
I will try
when design structure for building ,you usually use soft ?
thanks pro hi
Message 7 of 8
AJA14
in reply to: huyxp
Not sure I understand, but for design, I use several different software depending on the project itself, and the client requirements.
However, I use mainly Robot Structural Analysis.
Other good tools may be used such as S-Concrete.
Ali Al-Hammoud
Message 8 of 8
huyxp
in reply to: AJA14
thanks pro
I tried for tutorial of you,but I want tag beam automatic put on the structural plan when I draw any beam
