I started with the Wide Flange RFA that comes with Revit 2014 and then added the parameters for the spray on fire proofing. When I load it into my project it works. The issue is that the top of the steel beam drops down the thickness of the fire proofing. I want the beam to remain in the same location and the fire proofing to extend up and around the beam. Not sure how to get this to work correctly without using Z offset each time. Thanks for any help with this.
Solved by conormccartney3897. Go to Solution.
