Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Bar bending schedule using revit structure
6 REPLIES 6
6338 Views, 6 Replies
Is it possible to create bar bending schedule using revit structure.
I have a drawing of an industrial structure given to me. I want to create a bar bending schedule of the beams & structural members for execution of project. For that first I have to recreate the drawing since I don't have soft copy of drawing. Also I want to analyse the building using structural analysis softwares.
Structural detailing sucks. It's full of bugs. I could only create formwork drawings in ASD. Reinforcement sucks. Especially for industrial structures where there will be deep beams with side face reinforcements I couldn't use it.
I want to know work flow of how to do this.
Is this possible.
Design/recreate the building using Revit Structure > Advance concrete (for rebar scheduling) > Robot structural analysis.
Also I need tutorials (preferably video) of advance concrete & Robot
6 REPLIES 6
Yes you can detailing in Revit it has all the tools you need to put Reinforcement into your concrete structure. It also allows you to create bar bending schedules within the model. It does depend on which version you are using though as the tools have been enhanced over the last few releases, so I would recommend you use 2015.
I havent had any major issues with ASD it works fine for me.
Why dont you contact your local reseller for training and help.
Thanks for the heads up.
After your comment I found that revit extension was missing. Then I installed extension separately.
The auto rebar is awesome. But it's bit incomplete I feel.
The manual rebars in revit works but there is too much labour in that.
I have several other questions. (Am just learning these softwares)
is manual rebar is the only way to get rebars the way we want it.
In revits native rebar I tries distributing rebar on all sides of column but the corner bars overlap. How to merge those corner bars.
In auto reinforcement I can't have 8 rods in top extra bars. It allows me to select only in increments of 7 how do I get it to 8
Also what is the difference between rod Dia 32R & 32T
Can someone tell me, what should extensions program be downloaded for bar bending schedule revit 2017?
is that "masonry iq" is the only option for that? ty for the advice..
-FDC-
You don't need extensions for rebar schedules.
Standard Revit can do this but you have to make your own schedules (quite easy).
in reply to: -FDC-
oow.., im beginner, so i dont know revit can do bar bending, ty for ur
advice..
shefypattambi
Hii..please look at this link and also you can download the rebar shape family with shape image if you are using BS rebar shape
http://blogs.autodesk.com/bim-and-beam/2016/12/19/rebar-shape-images-in-revit/
https://revitbeyondbim.wordpress.com/2016/12/15/rebar-shape-images-in-revit/
Also you can use soffistick Rebar Tools..Smiley Happy
