Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Bar Joist Connections
3 REPLIES 3
LisaDrago
819 Views, 3 Replies
Hello - I have a client with an issue and I am not sure how to fix it...
He is putting in bar joist and it is automatically connecting together and they do not want it to.
I have attached 2 images - the good one is what they want... The bad is what they are getting.
Any ideas?
Thanks.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
3 REPLIES 3
kathryn.langan
in reply to: LisaDrago
Hey Lisa,
I tried to reproduce this and wasn't able to. Do you have a really basic file (really just the two bar joists and the wide flange) that you could post?
Katie Langan
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
LisaDrago
Hello Katie - I may have solved this problem in looking at it again. When placing the joists they were touching - and then joining... If I moved it away a little - they would un-join and work the way they are needed to.
I tried to post a file with just two joise and a beam and it was still too big.. i even purged the file and cound not get it down small enough to post.
Thank you for the response!
LD
kathryn.langan
Hey Lisa,
You might be able to play around with the Z Direction Justification and Offset values to avoid a join at that location. I briefly mention how those could be used in a Revit Clinic post (http://revitclinic.typepad.com/my_weblog/2009/08/tips-for-beam-cutbacks-in-mediumfine-detail.html).
I'm glad it sounds like you might have figured it out - let us know if you're still having issues!
Katie Langan
Autodesk, Inc.
