Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
3D Background displays even when set to none
2 REPLIES 2
jasonmccool8686
564 Views, 2 Replies
So how do you get the background to not print at all? Using Revit Structure 2013 in Realistic visual style on a locked 3D view, it stills prints a grayish background even with the background set to none under graphic display options. We need it to just display the structure only. Thought none would do that, but apparently not...
2 REPLIES 2
In the "Graphic Display Options" dialog, do you have "Photographic Exposure" enabled (checked)?
If so, try unchecking that and see what you get.
Joe
Thanks. We had to enable the photgraphic exposure as the only workaround we could find to RS2013 not drawing the 3D views correctly. Objects behind other objects weren't being hidden, and were showing through instead on several different jobs, and that photgraphic exposure fixed it. Apparently we don't need that now after that last update. Thanks again.
Jason
