HI,
I using revit structure 2013 with the static analysis of frame in the extensions. I can get the loads into show in the frame analysis tables. The load combinations are visible. In the loads tab, there no loads. I get the self weight load.
But I do not get the point loads from Revit. What am I doing wrong.
Brett Lewis
Kevin Dolley, from our user experience team suggest on our wikihelp:
If you enable the visibility of dimensions in your analytical view, you can use the dimension to place the point load with more precision.
Likewise, you can enable the visibility of structural framing elements in the analytical view to allow the loads to snap to the physical model when placed.
Hope taht helps.
