Ao tentar instalar o Revit 2015 em um PC com Windows 8.1 x64 bits, aparece uma tela de erro, conforme imagem, tem tambem o arquivo de log que segue abaixo.
Se puderem me ajudar agradeço.
Erro Autodesk Revit 2015
2014/4/14:23:09:40 WW--Honorio WW-HONORIO === Setup started on WW-HONORIO by WW--Honorio ===
2014/4/14:23:09:40 WW--Honorio WW-HONORIO Path_Length: 155
2014/4/14:23:09:40 WW--Honorio WW-HONORIO Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm
2014/4/14:23:09:40 WW--Honorio WW-HONORIO Launch
2014/4/14:23:09:40 WW--Honorio WW-HONORIO CommandLine
2014/4/14:23:09:40 WW--Honorio WW-HONORIO Setup Windows update reboot is pending
2014/4/14:23:10:24 WW--Honorio WW-HONORIO Setup Autodesk Revit 2015 Will restart automatically.
2014/4/14:23:10:24 WW--Honorio WW-HONORIO === Setup ended ===
2014/4/14:23:15:53 WW--Honorio WW-HONORIO === Setup started on WW-HONORIO by WW--Honorio ===
2014/4/14:23:15:53 WW--Honorio WW-HONORIO Path_Length: 155
2014/4/14:23:15:53 WW--Honorio WW-HONORIO Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm
2014/4/14:23:15:53 WW--Honorio WW-HONORIO Launch
2014/4/14:23:15:53 WW--Honorio WW-HONORIO CommandLine
2014/4/14:23:15:54 WW--Honorio WW-HONORIO Path_Length: 155
2014/4/14:23:15:54 WW--Honorio WW-HONORIO Current Directory C:\Users\WW--HO~1\AppData\Local\Temp\_AI40C8.tmp
2014/4/14:23:16:15 WW--Honorio WW-HONORIO === Setup ended ===
2014/4/14:23:16:08 WW--Honorio WW-HONORIO === Setup started on WW-HONORIO by WW--Honorio ===
2014/4/14:23:16:08 WW--Honorio WW-HONORIO Path_Length: 155
2014/4/14:23:16:08 WW--Honorio WW-HONORIO Current Directory C:\Users\WW--HO~1\AppData\Local\Temp\_AI40C8.tmp
2014/4/14:23:16:08 WW--Honorio WW-HONORIO Launch
2014/4/14:23:16:10 WW--Honorio WW-HONORIO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\WW--HO~1\AppData\Local\Temp\_AI40C8.tmp\Setup\RevitSetup.dll
2014/4/14:23:16:10 WW--Honorio WW-HONORIO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/14:23:16:14 WW--Honorio WW-HONORIO Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\WW--HO~1\AppData\Local\Temp\_AI40C8.tmp\Setup\RevitSetup.dll
2014/4/14:23:16:14 WW--Honorio WW-HONORIO Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2014/4/14:23:16:15 WW--Honorio WW-HONORIO PageOpen LaunchDialog
2014/4/14:23:18:20 WW--Honorio WW-HONORIO PageOpen LicenseDialog
2014/4/14:23:18:23 WW--Honorio WW-HONORIO PageOpen ProductInfoDialog
2014/4/14:23:19:47 WW--Honorio WW-HONORIO PageOpen ProductSelectionDialog2
2014/4/14:23:20:53 WW--Honorio WW-HONORIO PageOpen FullProgressDialog
2014/4/14:23:20:53 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2014/4/14:23:21:11 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2014/4/14:23:21:12 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\WW--HO~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/14:23:21:27 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2014/4/14:23:21:27 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2014/4/14:23:21:44 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2014/4/14:23:21:44 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/14:23:22:23 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/4/14:23:22:24 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/4/14:23:23:03 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/4/14:23:23:03 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:23:23:03 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Failed Installation aborted, Result=2
2014/4/14:23:23:03 WW--Honorio WW-HONORIO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/14:23:23:03 WW--Honorio WW-HONORIO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/4/14:23:23:03 WW--Honorio WW-HONORIO Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/14:23:23:07 WW--Honorio WW-HONORIO PageOpen InstallCompleteDialog
2014/4/14:23:23:27 WW--Honorio WW-HONORIO === Setup ended ===
2014/4/14:23:33:44 WW--Honorio WW-HONORIO === Setup started on WW-HONORIO by WW--Honorio ===
2014/4/14:23:33:44 WW--Honorio WW-HONORIO Path_Length: 155
2014/4/14:23:33:44 WW--Honorio WW-HONORIO Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm
2014/4/14:23:33:44 WW--Honorio WW-HONORIO Launch
2014/4/14:23:33:44 WW--Honorio WW-HONORIO CommandLine
2014/4/14:23:33:44 WW--Honorio WW-HONORIO Current Directory C:\Users\WW--HO~1\AppData\Local\Temp\_AI9BBB.tmp
2014/4/14:23:33:47 WW--Honorio WW-HONORIO === Setup ended ===
2014/4/14:23:33:45 WW--Honorio WW-HONORIO === Setup started on WW-HONORIO by WW--Honorio ===
2014/4/14:23:33:45 WW--Honorio WW-HONORIO Path_Length: 155
2014/4/14:23:33:45 WW--Honorio WW-HONORIO Current Directory C:\Users\WW--HO~1\AppData\Local\Temp\_AI9BBB.tmp
2014/4/14:23:33:45 WW--Honorio WW-HONORIO Launch
2014/4/14:23:33:45 WW--Honorio WW-HONORIO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\WW--HO~1\AppData\Local\Temp\_AI9BBB.tmp\Setup\RevitSetup.dll
2014/4/14:23:33:45 WW--Honorio WW-HONORIO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/14:23:33:47 WW--Honorio WW-HONORIO Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\WW--HO~1\AppData\Local\Temp\_AI9BBB.tmp\Setup\RevitSetup.dll
2014/4/14:23:33:47 WW--Honorio WW-HONORIO Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2014/4/14:23:33:47 WW--Honorio WW-HONORIO PageOpen LaunchDialog
2014/4/14:23:33:49 WW--Honorio WW-HONORIO PageOpen LicenseDialog
2014/4/14:23:33:51 WW--Honorio WW-HONORIO PageOpen ProductInfoDialog
2014/4/14:23:35:07 WW--Honorio WW-HONORIO PageOpen ProductSelectionDialog2
2014/4/14:23:36:34 WW--Honorio WW-HONORIO PageOpen FullProgressDialog
2014/4/14:23:36:35 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/14:23:36:36 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/4/14:23:36:36 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/4/14:23:36:36 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/4/14:23:36:36 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:23:36:36 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Failed Installation aborted, Result=2
2014/4/14:23:36:36 WW--Honorio WW-HONORIO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/14:23:36:36 WW--Honorio WW-HONORIO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/4/14:23:36:37 WW--Honorio WW-HONORIO PageOpen InstallCompleteDialog
2014/4/14:23:39:33 WW--Honorio WW-HONORIO === Setup ended ===
2014/4/14:23:47:20 WW--Honorio WW-HONORIO === Setup started on WW-HONORIO by WW--Honorio ===
2014/4/14:23:47:20 WW--Honorio WW-HONORIO Path_Length: 155
2014/4/14:23:47:20 WW--Honorio WW-HONORIO Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm
2014/4/14:23:47:20 WW--Honorio WW-HONORIO Launch
2014/4/14:23:47:20 WW--Honorio WW-HONORIO CommandLine
2014/4/14:23:47:20 WW--Honorio WW-HONORIO Current Directory C:\Users\WW--HO~1\AppData\Local\Temp\_AIFC8.tmp
2014/4/14:23:47:25 WW--Honorio WW-HONORIO === Setup ended ===
2014/4/14:23:47:21 WW--Honorio WW-HONORIO === Setup started on WW-HONORIO by WW--Honorio ===
2014/4/14:23:47:21 WW--Honorio WW-HONORIO Path_Length: 155
2014/4/14:23:47:21 WW--Honorio WW-HONORIO Current Directory C:\Users\WW--HO~1\AppData\Local\Temp\_AIFC8.tmp
2014/4/14:23:47:21 WW--Honorio WW-HONORIO Launch
2014/4/14:23:47:22 WW--Honorio WW-HONORIO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\WW--HO~1\AppData\Local\Temp\_AIFC8.tmp\Setup\RevitSetup.dll
2014/4/14:23:47:22 WW--Honorio WW-HONORIO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/14:23:47:25 WW--Honorio WW-HONORIO Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\WW--HO~1\AppData\Local\Temp\_AIFC8.tmp\Setup\RevitSetup.dll
2014/4/14:23:47:25 WW--Honorio WW-HONORIO Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2014/4/14:23:47:25 WW--Honorio WW-HONORIO PageOpen LaunchDialog
2014/4/14:23:47:39 WW--Honorio WW-HONORIO PageOpen LicenseDialog
2014/4/14:23:47:40 WW--Honorio WW-HONORIO PageOpen ProductInfoDialog
2014/4/14:23:50:36 WW--Honorio WW-HONORIO PageOpen ProductSelectionDialog2
2014/4/14:23:51:17 WW--Honorio WW-HONORIO PageOpen FullProgressDialog
2014/4/14:23:51:17 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/14:23:51:18 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/4/14:23:51:18 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/4/14:23:51:18 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/4/14:23:51:18 WW--Honorio WW-HONORIO Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:23:51:18 WW--Honorio WW-HONORIO Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Failed Installation aborted, Result=2
2014/4/14:23:51:18 WW--Honorio WW-HONORIO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/14:23:51:18 WW--Honorio WW-HONORIO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
Erro Autodesk Revit Content Libraries 2015
Solucionado! Ir para Solução.
Solucionado por williamhm. Ir para Solução.
tenta atualizar/instalar estes programas manualmente
Você achou uma postagem útil? Então fique à vontade para curtir essas postagens!
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão Aceitar Solução.
Fábio Santana
Architect | CAD/BIM Manager
Consegui solucionar o problema de instalação, tanto do Revit 2015 como do Autocad 2014 que tambem estava apresentando essse mesmo erro.
Abri a pasta Disco Local C, cliquei com o botão direito do mouse na pasta Autodesk (local na qual eu extrai a instalação do Revit e Autocad) e cliquei em Propriedades, depois que abriu a janela cliquei na guia Segurança, no campo Nomes de grupo ou usuários cliquei no usuário Administradores, no campo Permissões para usuários autenticados as permissões estavam todas desativadas, ativei tudo e dei Aplicar e Ok, depois executei o arquivo setup da instalação do Revit e do Autocad como administrador e funcionou.
Obrigado pela ajuda pessoal.
OBS: Consegui achar esta solução pelo post do marco.brasiel, que pediu pra verificar se eu tinha acesso de administrador.
Boa noite!
Um erro parecido acontece comigo. Estou tentando instalar a versao de estudante AutoCad 2015. Baixei os arquivos, estão já descompactados. Segui todos os conselhos aqui e em outros lugares. Além de baixar varias vezes. Não sei mais o que fazer, se puderem me ajudar!
Felipe,
É bem provável que o seu problema também seja de permissão de administrador do Windows.
Caso isto não resolva, tente postar o seu problema na página do AutoCAD.
Boa sorte!
boa noite
Estou com esse mesmo erro do felipe.ross.oliveira, tanto para o revit 2015 quanto para o autocad 2015, a única diferença é que o meu SO é o windows 8 single language
Olá
Tente fazer a instalação usando o Agente Virtual, pelo link http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
Na página do agente, escolha a opção Download Links na coluna da direita e vá navegando até a versão do software que você quer.
Desative seu antivirus e firewall para fazer a instalação e certifique-se que você possui permissões de administrador do seu Windows.
Boa sorte!
Consegui solucionar! É só mudar o diretório da pasta Temp e Tmp para uma qualquer criada no C: , além é claro de habilitar os arquivos, como foi dito pelo williamhm antes aqui.
(Depois você volta com ela pro lugar antigo)
Vai em executar > regedit > H_KEY_CURRENT_USER > Environment . Mude o diretório das duas pastas para a novo destino criado no Disco C. Você consegue fazer isso clicando na coluna dados.
Para acessar Executar no Windows 8, clique com o botão direito onde estaria o icone INICIAR.
Foi assim que consegui. Espero que consiga também.
Obrigado
Conseguir resolver de outra maneira, atualizei para o windows 8.1
Aconteceu a mesma coisa com a minha instalação, dá erro em todos os itens.
Analisei a permissão e instalei como administrador, mesmo assim continua dando o mesmo erro
alguém tem outra opção de solução?
Obrigado
Olá, pesso-lhes ajuda para a instalção do Revit Architecture 2015
Os requisitos da minha máquina corresponde ao que é indicado, fiz a reinstalação do Windows e o problema permanece; aparecendo a seguinte mensagem em anexo.
Aguardo Contato com soluções, obrigado.
Instale as atualilzações do windows.
Ola Pessoal , me ajudem por favor, eu consegui instalar o revit 2015, mas quando eu abro ele simplesmente nao funciona como o normal.
A barra de ferramentas nao aparece de principio, so se eu passar o mouse , entao comecam a aparecer os icones.
Na barra de propriedades a mesma coisa, e mesmo que eu selecionar por exemplo uma parede mesmo assim nao aparecem as propriedades.
E por ultimo na Barra de status la em baixo, fica a oscilar sem parar. E depois de algum tempo o programa deixa de funcionar e eu nao consigo mais fazer absolutamente nada.
Me ajudem a resolver POR FAVOR.
Não, sei oque eu faço quando abre esta janela. Alguém poderia me ajudar?
Eu tenho esse erro sempre que tento instalar. Quando ele termina o download aparece esse erro, não sei mesmo o que fazer.
Acredito que não seja problema com o administrador
o meu windows é 8.1
Estou tentando instalar a versão de estudante do Revit 2015 e Autocad 2015 e consta o mesmo erro para os 2 programas, abaixo esta o erro que aparece como faço para corrigir este erro de vinculo dinâmico?
Não encontrou o que está procurando? Pergunte à comunidade ou compartilhe seu conhecimento.
