Boa tarde pessoal,
eu estou tentando instalar o REVIT 2013 em portugues, para Windowns e nao estou conseguindo.
Meu pc é HP, W7, i5, memoria de hd de 400Gb.
Ja tentei várias vezes. Atualmente eu estou na espanha e o computador comprei aqui, será que tem algum problema? Creo que n.
A instalacao passa pela etapa de verificacao do sistema, pelo contrato, e tudo.
Vou copiar uma parte do texto do ERRO. Eu sinceramente nao entendo nada desse texto.
2013/5/27:14:53:46 Menezes MENEZES-HP === Setup started on MENEZES-HP by Menezes ===
2013/5/27:14:53:46 Menezes MENEZES-HP Launch
2013/5/27:14:53:46 Menezes MENEZES-HP CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-39119463 /PK 829E1 /student /skipEULA /akamai /auth /sid
2013/5/27:14:55:55 Menezes MENEZES-HP === Setup ended ===
2013/5/27:14:53:48 Menezes MENEZES-HP === Setup started on MENEZES-HP by Menezes ===
2013/5/27:14:53:48 Menezes MENEZES-HP Launch
2013/5/27:14:54:42 Menezes MENEZES-HP Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET...
2013/5/27:14:55:55 Menezes MENEZES-HP Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET...
2013/5/27:14:55:55 Menezes MENEZES-HP PageOpen LaunchDialog
2013/5/27:15:00:09 Menezes MENEZES-HP PageOpen LicenseDialog
2013/5/27:15:00:09 Menezes MENEZES-HP PageOpen ProductInfoDialog
2013/5/27:15:00:09 Menezes MENEZES-HP PageOpen ProductSelectionDialog2
2013/5/27:15:00:26 Menezes MENEZES-HP PageOpen FullProgressDialog
2013/5/27:15:00:27 Menezes MENEZES-HP Download Play VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR...
2013/5/27:15:00:35 Menezes MENEZES-HP Download Complete VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR...
2013/5/27:15:00:35 Menezes MENEZES-HP Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Menezes\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/5/27:15:01:00 Menezes MENEZES-HP Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2013/5/27:15:01:01 Menezes MENEZES-HP PageOpen InstallCompleteDialog
2013/5/27:15:13:36 Menezes MENEZES-HP === Setup ended ===
2013/5/27:18:40:42 Menezes MENEZES-HP === Setup started on MENEZES-HP by Menezes ===
2013/5/27:18:40:42 Menezes MENEZES-HP Launch
2013/5/27:18:41:04 Menezes MENEZES-HP === Setup ended ===
2013/5/27:18:40:48 Menezes MENEZES-HP === Setup started on MENEZES-HP by Menezes ===
2013/5/27:18:40:48 Menezes MENEZES-HP Launch
2013/5/27:18:40:59 Menezes MENEZES-HP PageOpen LaunchDialog
2013/5/27:18:45:38 Menezes MENEZES-HP PageOpen LicenseDialog
2013/5/27:18:45:54 Menezes MENEZES-HP PageOpen ProductInfoDialog
2013/5/27:18:46:47 Menezes MENEZES-HP PageOpen ProductSelectionDialog2
2013/5/27:18:46:59 Menezes MENEZES-HP PageOpen FullProgressDialog
2013/5/27:18:46:59 Menezes MENEZES-HP Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_2013_Portuguese_Brazil_Win_32-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Menezes\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/5/27:18:47:23 Menezes MENEZES-HP Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2013/5/27:18:47:23 Menezes MENEZES-HP Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Autodesk\Autodesk_Revit_2013_Portuguese_Brazil_Win_32-64bit\3rdParty\x64\VCRedist\2005\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Menezes\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/5/27:18:47:51 Menezes MENEZES-HP Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2013/5/27:18:47:51 Menezes MENEZES-HP Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\Autodesk_Revit_2013_Portuguese_Brazil_Win_32-64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
2013/5/27:18:48:03 Menezes MENEZES-HP Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/5/27:18:48:03 Menezes MENEZES-HP Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=pt-BR ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2013_Portuguese_Brazil_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/5/27:18:48:08 Menezes MENEZES-HP Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86)
da uma lina nesta conversar, é sobre a instalação do AutoCAD, mas me parece que você esta com o mesmo problema
http://forums.autodesk.com/t5/AutoCAD-Portugu%C3%AAs/AutoCad-2014/m-p/3934455#M1151
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão Aceitar Solução.
Fábio Santana
Architect | CAD/BIM Manager
Não encontrou o que está procurando? Pergunte à comunidade ou compartilhe seu conhecimento.
