Revit MEP Forum
wrong calculation result with dgC
1 REPLY 1
mrimmer
523 Views, 1 Reply
When I want to calculate with °C units, MEP gives me wrong results.
For example:
1°C * 1 = 1 ... OK
1°C * 2 = 275.15 °C ... ?
1°C * 3 = 549.3 °C ... ?
1°C * 4 = 823.45 °C ... ?
Does anyone have a similar problem?
Thank you.
1 REPLY 1
julianjameson8403
in reply to: mrimmer
Looks like a bug.
The initial temperature given when setting up the parameter appears to be the Celsius equivalent of 1 degree Kelvin? Probably an error in Revits hard coded conversion formula.
Autodesk needs to investigate this by the looks of it.
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
