Revit MEP
Valued Contributor
pverduzco
Message 1 of 2 (156 Views)
valve line type
156 Views, 1 Replies
07-10-2013 10:14 AM
In Revit 2013
I have a Deionized water return line that’s is hidden line type. The valve that I placed on this line is also taking on the line type. How and where can I go to edit the line type for this valve specifically on this system. ?
the Detail Level is in Medium.
the visual style is Hidden
CADastrophe
Message 2 of 2 (142 Views)
Re: valve line type
07-10-2013 12:07 PM in reply to: pverduzco
If a Line Pattern is being assigned by the System Graphics Overrides, then it will be bestowed upon the fittings and accessories connected to that System as well. Based on the priority of the Overrides, you have two options, each of which will have to be performed in every View in which the valve appears:
1. Create a View Filter that effects that Family (or even the entire Category), add it to the necessary Views, and set the Lines Override to "Solid".
2. Select the element(s), right-click, and go to 'Override Graphics in View' » 'By Element...' and set the Pattern Override to "Solid".
Just let us know if you run into any difficulties with this.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
