Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
tag for pipe accessory
11 REPLIES 11
Message 1 of 12
10893 Views, 11 Replies
i am trying to tag an air separator. which tag family is correct?
thanks
aj
11 REPLIES 11
Message 2 of 12
KyleB_Autodesk
Alan,
Depends on what info you want in the tag. I suspect it's easiest just to make a tag yourself, it's quite simple, just set the Family Category to Pipe Accessory Tag, and then define the Parameters you want to show up.
Cheers,
Kyle B
Revit MEP Product Manager
http://inside-the-system.typepad.com/
Kyle Bernhardt
Director
Building Design Strategy
Autodesk, Inc.
Message 3 of 12
excellent
i was not aware of the Family Category option under Settings. i just duplicated a Tag and changed that setting.
thanks
aj
Message 4 of 12
KyleB_Autodesk
Glad to help.
Cheers,
Kyle B
Kyle Bernhardt
Director
Autodesk, Inc.
Message 5 of 12
in reply to: KyleB_Autodesk
my system tells me to load the "pipe accessory tags", but when I go to look for them they are no where to be found.
Message 6 of 12
Message 7 of 12
CoreyDaun
stevemarquiss wrote:
"my system tells me to load the "pipe accessory tags", but when I go to look for them they are no where to be found."
You will have to create one, which is pretty easy. Go to the Application Menu (the big "R") and to New ► Family. In the Annotations folder, just select the "Generic Tag" as your Template, and once it's open, click "Family Categories and Parameters" (the icon with the image of a folder) and select "Pipe Accessories" from the list of Categories. Hit 'OK'. Now all you have to do is place a Label and then configure that Label to report the desired Parameters.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 8 of 12
in reply to: CoreyDaun
Thanks Corey D. I remember seeing this procedure somewhere in the last 3-4 months of learning Revit. But, there's been too much and i needed this reminder. I've been using Lynda.com for video training, but their outlines aren't always detailed enough and I couldn't find the subject in their outline. So, thanks.
Message 9 of 12
hy, i need help with placing pipes in 3d model in revit 2015. when i select objects and want them to place, all i see is lines, not models, can someone help me with loading pipe accessories family into revit
thx
Message 10 of 12
fabiosato
If you want to have the 3D representation, change the view detail level to fine.
Regarding the pipe accessories, you need to load them, use the Load Family command in the Insert tab, browse in the library after the pipes accessories.
Fábio Sato
Message 11 of 12
in reply to: fabiosato
Where to find pipe library? I need classic pođeš for deset and water supply
Poslano s mobitela sa sustavom Windows 10
Message 12 of 12
fabiosato
Victaulic and Charlotte Pipe have some fittings, the pipes should be set in the project file since they are system families.
Fábio Sato
