There are times when I cut a section, the top of view range or clip planes just shoots up.
Is there a way to control this.
Solved by CoreyDaun. Go to Solution.
You can't control the default, really - I always have it shoot clear across the building. What I do is right after I create the Section (and while it's still selected), I change the "Far Clip Offset" under Properties to 10', which bring it back the general area.
Hi Ali,
That functionality may not be available in Revit MEP. Can you post a screenshot of what you're referring to?
How would a View Type change the far clip offset? Unless you were tieing that View Type to a View Template? (which by the way, can make creating sections VERY slow, if you have crazy visibility graphic overrides associated with the View Template as you're creating the section(
