hi im newish to revit been backgroud reading since 2010 im finding it very tight to run on pipework for domestic servise just hooked up a school with 80 stacks which makes 160 plus sinks and drains if the liitle blue alignment line would also do 45 degrees to centers it would be great as ive found the same onthe mep autorouting in small spaces it like reverse pole magnets real hard work esp whenyou in project environments with no forwardplanning and needit now approach thanks....
Hi Sandy, and welcome to the Discussion Groups!
Your post here is a bit difficult to follow, having no punctuation and all, so I'm not entirely certain what issue you are having. Can you explain a little bit more? Perhaps an image could help?
