Revit MEP
Message 1 of 3 (155 Views)
Accepted Solution
revit 2012 crash
155 Views, 2 Replies
01-14-2014 11:56 AM
I have had problems with Revit 2012 frequently crashing when manipulating sections
With the section view open, I can move the scope box with no problems, however, when I try to move the section itself, Revit often crashes. I found that closing the view, moving the section line then re-opening the view works without problem.
Has anybody else had this problem?
*Expert Elite*
CADastrophe
Message 2 of 3 (105 Views)
Re: revit 2012 crash
01-16-2014 07:36 AM in reply to: alatier
I haven't had this problem, but try toggling "Use Hardware Acceleration" under Options > Graphics. Also, verify that your graphics card is on "the list"; >this link< might be helpful.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Product Support
Message 3 of 3 (94 Views)
01-16-2014 06:11 PM in reply to: alatier
Please check that you have already updated all service pack and hotfixs for Revit 2012.
The Update and hotfix for revit you can find on this link below :
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9273944
Arief Rahman
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
