We have a couple projects that when the arch client links in our MEP file, they continuously get a reposition msg that the MEP has been moved from <current>. We can select any option, but it keeps coming back. This project NEVER had shared coordinates, and only linked in via Origin-Origin.
We would prefer to select the third option: Disable Shared Parameters, but it doesn't take when we select it and keeps popping back up.
Any suggestions?
Solved by Lance.Coffey. Go to Solution.
The following document has information on this issue:
Location Position Changed dialog when saving in Revit
http://usa.autodesk.com/getdoc/id=TS14334953
If after clicking "Disable shared positioning", closing the project, and then reopening it (as described in the link above), the message returns, try selecting the linked MEP project, open the Shared Location dialog, select Do not share location of selected instance and click OK.
