hi
can we open a old project with a newly created project template.
i can open only new project with newly created project template.
present we are using transfer project standards.i am using revit mep 2014.
thanks in advance.
Solved by CoreyDaun. Go to Solution.
A Project Template must be used at the time the Project is first created; Once a Project is created, you must use Transfer Project Standards or similar means to import data.
