Revit MEP
Valued Contributor
Message 1 of 2 (127 Views)
project Phases & Phase Filters
127 Views, 1 Replies
01-23-2013 06:08 AM
I am having difficulties making my views look like the architects's.He created 6 project phasess, &
renamed & created more phase filters...Should I match/duplicate his?
Active Contributor
Message 2 of 2 (104 Views)
Re: project Phases & Phase Filters
01-24-2013 07:37 AM in reply to: EddieFromDC
That sounds like a lot of phases to manage, so I would proceed with caution. We see a lot of improperly phased projects via our tech support system.  One red flag is when we see a phase called "demolition".  This is usally created when someone doesn't understand how phasing works in Revit.
I think that if the phases are well thought out and truly relate to the timing of different parts of the projects development, and your work will also occur during all those phases then it may make sense.   It definitely warrants a coordination meeting with the architect.
Automatic Mapping relies on phase names corresponding:  http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/2278-Collabor2278/2279-Linked_M2279...
Mapping Phases:  http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/2278-Collabor2278/2279-Linked_M2279...
Good luck!
Glynnis Patterson, Architect
www.ideatebimlink.comwww.ideateexplorer.com
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
