Dear all
i attached to you a picture showing the problem i have
i created an FCU unit and made piping on the side, on family i made pipe connector
and now
picure on the left showing the top view for the level, as you can see the the pipe i drew manually is showing with 2" size
there is a pipe i drew from the FCU that is not showing on the top view, BUT it is showing on the section
any idea abuot that problem ? as i drew the pipes manually
i have checked all the possible underlay option (as only i have 3 levels) but nothing is showing
can you help me please
reagrds
Sorry for the delay in response.
This could be a number of possible issues, including:
- The elements are on a Workset that is turned off.
- The elements are being affected by a View Filter.
- There is an Underlay (which you mentioned that you checked). An Underlay can cause strange display issues.
- There a Plan Region present.
