Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
problem with ceiling view
2 REPLIES 2
chunky2k
320 Views, 2 Replies
hi all
i have problem with the ceiling view (i attached a photo)
as you can see on the vertical red line
on the right side : there is 600x600 ceiling
on the left side    : there is nothing showing
i insered a black box to tell you there is a ceiling not showing
the ROOF level on the right side is 9 meters but on the left side it is 6 meters, so the roof view is blocking the ceiling view
i tried to create new level between the both levels (9 and 6) but it is not working
i want to the whole ceiling to be shown
is it possible ?
regards
Variable Integrated Package L.L.C
Abu Dhabi - United Arab Emirates
2 REPLIES 2
CoreyDaun
in reply to: chunky2k
Have you tried setting the Roof Category to 100% Transparency?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
thamizhz
Are u Trying To Use View Range In Properties tap.. also visible setting..???
