Revit MEP
m9905101
Message 1 of 2 (206 Views)
pipe system in 3D drawin
206 Views, 1 Replies
05-20-2012 12:30 PM
Hello everyone, I need some help about how to create pipe system
When I created pipe system, it always show lines
I can't see the 3D pipe system in 3D diagram
I tried to modify some setting such as diameter...but it still had probram
Does anyone can tell me how to solve the probram?
Thanks for replying!!
Valued Mentor
julianjameson8403
Message 2 of 2 (200 Views)
Re: pipe system in 3D drawin
05-21-2012 01:13 AM in reply to: m9905101
It's all about the level of detail. The checkerboard buton at the bottom of the screen is currently set to medium so you will only see single line pipes. Change it to Fine and then you will see double line pipes.
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
