Is there a way to adjust how a wire looks, ie. hidden, dash dot etc. I tried making a subcategory under wires under object styles but I can't assign the wires to that subcategory. Also, Is there a way to modify the appearance of panel schedules when put on a sheet? I don't need to change the information layout of the panel just the size. Currently I can only get 3 panel schedules on a 36" X 48" sheet. You can imagine how big they are. We also have around seventy panel schedules so modifying each one with the grips would take more time than anyone has. Is there a quick fix?
