Revit MEP
Valued Contributor
Sandleaz
Message 1 of 4 (492 Views)
out of the box generic pipe elbows
492 Views, 3 Replies
10-28-2012 02:39 AM
Perhaps someone can explain to me on why the out of the box generic welded elbows aren't as customizable as they should be?  If the elbow is 90 degrees, it appears to be a short radius elbow.  However, if the elbow is acute (less than 90 degrees), the elbow has a longer turn radius.  It also appears to have a varying turn radius as the angle changes --- which I don't really understand.  I've had to copy/paste/modify the out of the box family to get elbows with a turn radius that can be controlled by user (instance parameter) and change a few other parameters.
It's not something new, but I've never really understood this.
Active Contributor
sforsberg215
Message 2 of 4 (483 Views)
Re: out of the box generic pipe elbows
10-28-2012 05:18 PM in reply to: Sandleaz
Architects designed the mechanical systems and the various bits and pieces. The why I have never understood, either. Sent from my iPad
Valued Contributor
Message 3 of 4 (465 Views)
10-29-2012 08:10 AM in reply to: sforsberg215
I posted something similar to this, a few weeks ago.  I noticed some of the PVC drain elbows had a different sweep at certain sizes.  The problem is in the out-of-the-box look-up tables.  I had suspected that other families had this problem as well.  I had to modify the look-up table and distribute that to my users.  That complicates the software mantenance process.  I will have to look into your solution.
Valued Contributor
Sandleaz
Message 4 of 4 (442 Views)
10-31-2012 08:11 AM in reply to: RandMan
I am not sure it's the data in the look up tables that is incorrect --- or at least that's not the only thing.  The fitting outer diameter values in the look up table are close to REVIT's default values for a schedule 40 carbon steel pipe.  The formula for the turning radius varies with the angle.  This occurs with the default pvc elbow as well.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
