Show only
Search instead for
Drawing some supply ducts in Revit MEP and exported out to Navisworks .nwc, I can only see white color on supply ducts. What's the way to show color (blue for supply, pink for return...)
Filters do not go with the NWC file, so color coding won't happen. The way I have done what you describe is use the Properties filters in Navisworks to isolate out the various duct work and then apply a Presenter material or color to the objects.
