Revit MEP Forum
Welcome to Autodeskā€™s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Showing results forĀ
Did you mean:Ā
multi-circuit homerun
3 REPLIES 3
davidwilliamedwards
1682 Views, 3 Replies
How do I show a multi-circuit homerun originating from one electrical device with multiple electrical connectors?
I have figured out how to add multiple electrical connectors to a device, and how to connect those to separate circuits on the panel. I am lost at the point of getting the single homerun to acknowledge the multiple circuits.
David William Edwards
Dave Edwards Consulting
3 REPLIES 3
The parameters and information from secondary connectors and beyond cannot be tagged. There have been many who have brought up this issue. I would strongly recommend reporting this with Autodesk Feedback/Support.
There is one possible workaround, though. You may not be able to tag the element, but you can tag the wire coming off of the secondary connector. If you are not showing wiring, you can draw a piece of wire and then make it extremely small, so it does not shot up on the drawings.
ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€
āž|āž Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
I'm trying to do the same thing. Although multiple connecters per device probably isn't a good idea if you want to have accurate loads on your circuits.
It's weird Revit can't do this...
____________________________________________________
Please give kudos to the MEP Wish List ideas you like, as this will help the Revit development team prioritize functionality additions!
CoreyDaun
in reply to: adam.jw
Our issue with this stems from multi-ballast light fixtures, with one ballast as normal lighting and the other as emergency to a separate EM panel.
